1995 Saturn SL1 window
17,800 MILES • 4 CYL • FWD • AUTOMATIC
PARDO1987
driver side window is a manual window and it does not go down unless u give it a push down first. then it will catch on and you can use the manual handle.
Mar 25, 2010 at 4:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need to remove the door panel and inspect it. could be coming out of track slightly or faulty cables.
Mar 25, 2010 at 4:20 PM
