1995 Saturn SL1 Turn Signals and hazards not working
107,000 MILES • 4 CYL • 2WD • AUTOMATIC
WESTERLU495
My turn signals and hazard lights do not work. I checked all the fuses and was told to check the relay switch. I have looked everywhere and can't find where it is. Can you please tell me where to locate the relay box for the turn signals?
Nov 6, 2010 at 1:54 PM
SATURNTECH9
  • 30,869 POSTS
So do the turn signal's even light up at all?Your flasher relay Is on the back side of the inside fuse box on the drivers side.
Nov 6, 2010 at 2:17 PM
WESTERLU495
Neither my turn signals or my hazards work. I am unable to find the inside fuse box on the drivers side. I found the one on the passenger side but none on the drivers side. Is there a diagram online that will help me locate it?
Nov 6, 2010 at 4:24 PM
SATURNTECH9
  • 30,869 POSTS
I can't find a diagram to show you where it is.But on the drivers side right in front of the center console behind the small kick panel which would be the back side of the inside fuse box you will see the chime module which is at the bottom and rectangle shaped right above it is the flasher relay it's square.You already check to see if the hazard and turn signal fuse was good and had power to both side's of the fuse?
Nov 7, 2010 at 1:42 AM
WESTERLU495
Yes, I checked all the fuses both under the hood and inside the car. I also checked the box that is on the steering column. Thanks, I will look again today and let you know how it goes.
Nov 7, 2010 at 3:07 AM
