1995 Saturn SL1 starter
1995 SATURN SL1
155,000 MILES • 4 CYL • 2WD • AUTOMATIC
TIMROCCO1962
will start in morning drive to work 8 miles turn car off and try to start it and will not start for a coulpe hours after I turn it off. its like after its off for a few hours it will start.
Oct 15, 2008 at 3:11 PM
  • CAR REPAIR CONTRIBUTOR
Next time it will not start -do below to determine if its fuel or spark
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Oct 15, 2008 at 3:15 PM
