1995 Saturn SL1 Reasonable price for brakes/clutch?
70,000 MILES • 4 CYL • 2WD • MANUAL
DASHCON
Got quoted $678 to 1) replace front brakes and rotors, and 2) replace the clutch master cylinder and clutch slave and bleed the system.
Is that reasonable? Seems like a lot but I don't want to skimp on brakes.
Also, what is a reasonable price to replace the clutch on a '95 saturn?
Thanks!
Apr 20, 2010 at 9:25 AM
SATURNTECH9
  • 30,869 POSTS
[quote:01220fb5fa="dashcon"]Brakes problem
1995 Saturn SL1 4 cyl Two Wheel Drive Manual 70000 miles
Thanks![/quote:01220fb5fa]
first of thank u very much for ur donation.labor to replace ur rotors and pads is 1.5hrs times 80-100 per hr depending on labor rate.the rotors are 40 plus tax.the front pads depending on which quality u get for decent ones 40-60 plus tax.ur clutch master and slave u should get as a assembley thats the best way to get it.so u wont have to bleed it.labor is 1.2 hrs times 80-100 per hr depending on shop rate.the clutch master and slave assembley is 114 plus tax.ur clutch replacement labor is 7.3 hrs times 80-100 depending on shop rate.parts are 230 plus tax.so there some varibles depending on shop labor rate and also u could shop around on the parts as well that was just one store i checked for those prices.let me know if u have anymore questions.
Apr 20, 2010 at 10:32 AM
