1995 Saturn SL1 engine will not produce heat
1995 SATURN SL1
126,000 MILES • 4 CYL • FWD • AUTOMATIC
DYYDJBB
  • 7 POSTS
engine will not produce heat. installed new t-stat and new coolant and at an idle guage will get just below 1/2 way and blow heat, moving down the road air from the heater core is cold and temp guage drops all the way down. the drive to work is about 45min. and all hoses under hood are ice cold. I even tried removing the fan relay to disable the fans, this did not help. Any ideas?
Feb 3, 2009 at 11:59 PM
DYYDJBB
  • 7 POSTS
does anyone have any idea what can be check on this issue before summer gets here?
Feb 17, 2009 at 12:14 AM
