1994 Saturn SL1 will a 2000 engine fit a 1994
125,000 MILES • 4 CYL • FWD • AUTOMATIC
ETCH
I put a 2000 sl1 engine head and block in my 94. I transferred intake and manifold . Now I have a ignition code popping up. I was told it was because the cranks are different. i used the 1994 blown up engines cam sensor, will useing the 2000 cam sensor fix my problem or is there a way of fixing it. The car runs fine.
Apr 14, 2010 at 7:27 AM
SATURNTECH9
  • 30,869 POSTS
Let's start with what code do u have popping up?let me know.
Apr 14, 2010 at 8:09 AM
ETCH
19 ignition control 6 times
41 ignition control malfunction
44 oxygen sensor lean
53 knock sensor to much knock present
Apr 15, 2010 at 2:13 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1994_6x_wire_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1994_6x_trouble_tree_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1994_est_wire_diagram_1.jpg
the crank for 2000 sl1 and 1994 sl1 is the same it doesnt appear its the wrong is the problem.i gave u the 6x wire diagram and trouble tree ur code 41 is for ur knock sensor fault the electricial part of it.ur 53 is just a info flag usually goes with the 41.trace that code 19 down and let me know what u find there that may fix some of those other codes.let me know what u find.
Apr 15, 2010 at 5:23 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1994_6x_trouble_tree_part2_1.jpg
sorry about that the first 6x trouble i posted for u was cut off heres the complete one.let me know what u find.
Apr 15, 2010 at 5:35 AM
