1994 Saturn SL1 sTARTER
1994 SATURN SL1
125,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHN STILLWELL
Where is it exactly...if i,m standing in front of car.....r side under battery area.........left side under ac compressor area?? is it accesable from above or do i need jack stands and go from below??? someone told me its at bottom edge of engine block//?? how many bolts?? easy job???
Jul 16, 2010 at 12:04 PM
SATURNTECH9
  • 30,869 POSTS
It's under the intake manifold two bolt's holding it in.Then there is a big wire and little wire held on by one nut each.You have to get it from the bottom it's an easy job for me but i have replaced so many i have lost count.You might have trouble with the top bolt because you can't see it you just have to feel to get it out and to put it back in.
Jul 16, 2010 at 1:49 PM
