1994 Saturn SL1 Odometer not working....
215,000 MILES • 4 CYL • FWD • AUTOMATIC
PAFRESHCOLN
My odometer/trip odometer stopped working some time ago although all the other guages on the panal continued to work. This past weekend we installed another set of guages and everything works except the odometer and trip odometer once again. Is there something else we should replace? There is no cable but there has to be another sensor somewhere we are just unable to locate. Can someone please help me with this?
Jun 3, 2009 at 1:41 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is speedometer working?
Jun 3, 2009 at 3:24 AM
PAFRESHCOLN
Speedometer and Tachometer and gas gauge are all working working... the only ones not working are odometer and tripometer...
Jun 3, 2009 at 3:41 AM
DOCFIXIT
  • 18,828 POSTS
Can't find a reason the PCM drives the speedo via Vehicle Speed Sensor then an integerated circuit runs OD steper motor. So with speedo working the only thing I see is that circuit which is part of cluster. Are you certain OD worked in replacenent cluster.
Jun 3, 2009 at 6:53 AM
PAFRESHCOLN
No, I'm not sure it worked in previous vehicle but I thought it too coincidental that in 2 separate sets of guages... these are the only two items that don't work. (the odometer and the tripometer.) Is there a sensor somewhere else we could test or replace?
Jun 3, 2009 at 7:00 AM
DOCFIXIT
  • 18,828 POSTS
It works like I stated VSS is only sensor and it is working cause speedo works an intergrated circuit in cluster takes speedo pulses and drives OD so cluster has to be faulty
Jun 3, 2009 at 7:43 AM
PAFRESHCOLN
I thank you and will replace the cluster once again!
Jun 4, 2009 at 12:32 AM
