1994 Saturn SL1 no pulse to injector
12,000 MILES • 4 CYL • 2WD • MANUAL
KD58
  • 9 POSTS
car will run but have no pulse to good injector...no codes as I disconnected battery too soon (cannot bring ANY code now....shouldn't I get at least a 12???).What feeds pulse to injector? was going to replace speed sensor and then head to ECM....HELP...fuel and pressures ok....JUST NO PULSE Thanks KD58
Sep 28, 2010 at 8:04 AM
SATURNTECH9
  • 30,869 POSTS
The speed sensor has nothing to do with injector pulse's.How did you check for injector pulse's?Did you use a noid light or some other way?Let me know so we can figure this out.
Sep 28, 2010 at 8:28 AM
KD58
  • 9 POSTS
the pink wire to the injector is hot but the dark wire did nothing with a test light to battery hot while turning over...no pulse kd58 THANKS
Sep 28, 2010 at 12:42 PM
SATURNTECH9
  • 30,869 POSTS
The ecm control's the ground to the injector that's how it pulse's the injector.So do you have spark?If the injector ground side isn't pulse's it's going to be the wire's or the ecm.So what happens when you try to flash the code's out?You said it won't even give a code 12 which it should they all have that code.So what's the whole story?Did you just have a crank no start one day?Or did something happen to cause it to not start?
Sep 29, 2010 at 10:46 AM
KD58
  • 9 POSTS
thank you sooooo much...car runs with fuel or ether so must be puter or wire....while driving it burped three different times an a hot day so assuimed fuel pump even though it felt like spark....did checks...changed filter...now no codes????oh yeah we towed it last three miles kd58
Sep 30, 2010 at 2:11 PM
SATURNTECH9
  • 30,869 POSTS
If you have no injector pulse i would check fuel pressure also.But if all your missing is injector pulse then your left with the wiring and the computer if you try a computer i would find a good used one.
Oct 1, 2010 at 5:00 AM
KD58
  • 9 POSTS
do you know if the dk blue wire (pulse ground) it may be black goes directly to the ecu and if so I could probe at that connection where the wire comes out and it should pulse which I could then jump....but probably I'll need to replace the ecu.... thanks again KD58 (any chance of getting a diagram of the ecu showing where that wire should be?)
Oct 1, 2010 at 2:28 PM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1994_SL1_injector_diagram_1.jpg
Yes the light blue wire goes straight to the ecm and that is a pulsing ground while cranking.I would take a ohm's meter and go from the terminal to the injector to the terminal of the ecm it should be 2 ohm's or less.I also emailed you the diagram.
Oct 1, 2010 at 4:59 PM
KD58
  • 9 POSTS
Louie, you're my new best friend...the principle is surely the same but mine is a single injector with a dk. blue (or black) wire?????? thanks KD58 (where are you located and how will I know that YOU will get any $ )
Oct 2, 2010 at 3:22 AM
SATURNTECH9
  • 30,869 POSTS
If you look a little closer it show's both the four injector and single injector that's why it show's 5 injector's one of those injector's is labeled TBI which is throttle body injection which yours is.If you donate under the user name you used to ask the question with i will get the money i'm suppose to get when you donate no worries there.
Oct 2, 2010 at 3:41 AM
KD58
  • 9 POSTS
thank you louie...I have 2 ohms from ecu pin to injector so does that mean it is for sure the ecu???and should I pull that wire at the pin and look for anything specific? getting closer KD58
Oct 15, 2010 at 5:53 AM
SATURNTECH9
  • 30,869 POSTS
Nothing in life is for sure lol.But if you rule out the wire and terminal tightness then all your left with is the computer.If your getting 2 ohm's from terminal to terminal then there is no point in removing the wire from the connector.Now your left with terminal tightness and the computer.
Oct 15, 2010 at 6:33 AM
KD58
  • 9 POSTS
Louie...just a note to say thank you for guiding me through the diagnosis...I just replaced the ecu and it runs fine...was hoping for a different solution (obviously) but at least it is fixed...thanks again...going to send $ now kd58 in good ol Boring Oregon
Nov 6, 2010 at 5:04 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Your welcome glad to hear you got it figured out.I hope you got a used computer the new one's can be expensive.
Nov 6, 2010 at 3:01 PM
