1994 Saturn SL1 engine surges
1994 SATURN SL1
192,000 MILES • 4 CYL • FWD • AUTOMATIC
LITLEBITGRAM
i hv a 94 saturn 1.9 has been fine started to surge at idle and when i put on brake replaced plugs wires filters still surges also when 2 plugs were removed they were wet with oil
Nov 9, 2008 at 11:13 AM
Check your engine compression-that oil don't belong there-could be valves/rings problems
Surging-inspect and test the idle air control motor
Nov 9, 2008 at 10:08 PM
