1994 Saturn SL1 Clutch Does not disengauge completley
235,000 MILES • 4 CYL • FWD • MANUAL
GERRY CAMP
Replaced the clutch in the 94 Saturn. Clutch will not disengage completely to allow shifting. With the engine running, I press in the clutch, but the trans will not shift into gear. Stop the engine, shift into gear, start engine and the car wants to creep forward. I have bled the clutch slave cylinder, but this did not help.
Feb 18, 2010 at 2:36 PM
SATURNTECH9
  • 30,869 POSTS
When u replaced the clutch did u replace the clutch slave or master?is ur clutch pedal firm from the moment u start pushing it till it hits the floor?or does it go down a little ways before it get firm.let me know what u find.
Feb 19, 2010 at 3:50 AM
GERRY CAMP
No I did not replace the master and the slave cylinder. The pedal does go down a little before you start to feel pressure. I found another site today where they recommend replacing both at the same time as the clutch. Do you agree that I should do this.
Feb 19, 2010 at 4:19 AM
SATURNTECH9
  • 30,869 POSTS
If the pedal goes down some before it gets hard then u need to replace the clutch master and slave together get it as a assembly all together everyone that has bought the two seperately has never been able to get them to bleed I would start by replacing that first.what did the old clutch do that u repalced.let me know how it goes.
Feb 19, 2010 at 6:55 AM
GERRY CAMP
The clutch came apart is the reason we replaced it. We picked up a master and slave combo today and replaced them, problem solved. Thanks for the help!
Feb 19, 2010 at 9:06 AM
SATURNTECH9
  • 30,869 POSTS
Glad to hear u got it all figured out and fixed already ur welcome that's what were hear for. thanks for using 2carpros and feel free to use us again.
Feb 19, 2010 at 9:45 AM
