1994 Saturn SL1 brake lights
120,000 MILES • 4 CYL • FWD • MANUAL
TIGER2466
SOS,
My break lights stopped working. The left right and center one. I checked the bulbs and they are ok. I looked for the fuse and see only one 15 amp blade fuse under the hood. Is there another fuse im missing here? All other lights work including the tail lights.
Can anyone help me with this?
Thanx
T
Mar 6, 2009 at 11:14 AM
BMRFIXIT
  • 19,053 POSTS
Instrument panel fuse block is located under the dash panel ,left of steerin column. Fuse # 2 its 7.5Amp(brown) check brake light switch
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_238.jpg
Mar 6, 2009 at 11:30 AM
TIGER2466
Where is the brake light switch?
The 7.5 fuse #2 is the turn signal according to this diagram which is my fuse panel. Is this the brakes fuse also. I CHECKED any ways and is ok.
I did check under the hood and there is only one blade fuse 15 amp and i checked. I replaced too make sure also.
Thanks for all replies
Mar 6, 2009 at 1:15 PM
BMRFIXIT
  • 19,053 POSTS
brake light switch is located top of brake paddle
Mar 6, 2009 at 9:19 PM
TIGER2466
I now no i need too take this switch off, but how. It looks like they built the switch around the car.
I cannot get my hands in there, There is a fastner on a bold but what tool do i need to replace this?
Any info i can get would be way kool
Thanks...
Mar 8, 2009 at 11:52 AM
