I have replaced the slave clutch cylinder, bleed it 3 times. I did this because of the fact I suddenely couldn't shift into any gears ( without using alot of strength). I changed the part I thought would fix the problem. I was able to drive and shift( not easily) for about 10 blocks. I tried to drive the car and the shifting is just as bad as it was before. I also noticed that when in first gear--- ( clutch depressed) the car will drive forward. What can be the problem. I did replace the clutch close to 100,000 miles ago. Is that it? Also is there a chance the flywheel can be messed up too? I do need to drive this car for the next week coming up or I could lose my job, Is there anything I can do till next sat when I will change out the clutch, and flywheel. Please help me with the info I am looking for? Thank You for your time.( I would donate-- but I am struggling very bad. I haven't bought food in a month and now I am down to rice. Sorry I can't donate.
Jun 6, 2010 at 4:09 AM
