1993 Saturn SL1 Overheating
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
FLYBOYDAN
I have replaced the thermostat and heater core on my 93 SL1 and it overheats after driving for about 2 miles with the defroster running on high.
Jul 9, 2010 at 6:34 AM
SATURNTECH9
  • 30,869 POSTS
Does your engine cooling fan come on?Was it on when it over heated?How high was the gauge reading when it over heated?
Jul 9, 2010 at 6:42 AM
FLYBOYDAN
Cooling fan comes on and was on. It was all the way up with the defroster running on high.
Jul 9, 2010 at 10:08 AM
SATURNTECH9
  • 30,869 POSTS
How high was your gauge up too 3/4 red?Also does your radiator fan come on at 3/4?HAve you checked your coolant level to see if it's low or you have oil in your coolant?
Jul 9, 2010 at 1:22 PM
FLYBOYDAN
Radiator fan came on and it comes on at half on the gauge, coolant level is to the full on the overflow container and no oil in it. The oil is clean of other fluids also. It made it into the red.
Jul 9, 2010 at 3:14 PM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1993_sl1_engine__sensors_1.jpg
If your cooling fan come's on at half way on the gauge on your model year then your coolant temp sensor is bad.The fan should come on at about 3/4 on the gauge the sensor's are only like 10 make sure you get a brass tipped one.The plastic tipped one's crack also inspect the connector going to it if it's corroded replace the connector as well.Make sure the engine is cold you will loose some coolant.It's the bottom sensor with the two wires going to it.Also when your cooling fan is on that you have plenty of air pulling threw it or you have debris in the cooling fin's like sand bag's cat fur etc that will make your car over heat too.
Jul 10, 2010 at 1:42 PM
