1993 Saturn SL1 Oil Leak
1993 SATURN SL1
135,000 MILES • 4 CYL • FWD • AUTOMATIC
GRAND1963
  • 5 POSTS
I have noticed the smell of my car burning oil. I looked all over the engine and didnt see anything. I looked in the Air Intake system and I noticed oil inside of there. What can I do to fix this issue?
May 26, 2010 at 7:17 AM
SATURNTECH9
  • 30,869 POSTS
So is the oil in your air box?Inside or outside your throttle body?Please be more detailed if you could post some pictures better yet.Let me know.
May 26, 2010 at 9:02 AM
GRAND1963
  • 5 POSTS
Its outside of the throttle body. Where i can see oil present is right below the filter.
May 27, 2010 at 4:55 PM
SATURNTECH9
  • 30,869 POSTS
So it's under the air box on the outside of the throttle body?Maybe it's the valve cover gasket leaking?It's hard to say without seeing it.Is there anyway you could take some pictures and post them maybe you have a friend with a camera or a friend with a cell phone that takes pictures so I can see what your seeing?
May 27, 2010 at 5:45 PM
GRAND1963
  • 5 POSTS
Its not the Valve Cover Gasket causing that because I just had to replace that after I took the head out of my car.
Jun 4, 2010 at 3:59 AM
SATURNTECH9
  • 30,869 POSTS
There's not many place's for oil to leak there i wouldn't rule out the valve cover gasket since it was just replaced.They can be touchy when replacing them if there over torqued or too much silcone is used the gasket can pop out of place and leak.
Jun 4, 2010 at 6:14 AM
