1993 Saturn SL1 Horn Broke
RENDISHIONS
Electrical problem
1993 Saturn SL1 222222 miles
I just purchased this car. The blinkers didnt work when I got it and neither did the horn. I replaced the fuse for the blinkers/flashers and fixed that problem. The horn still dosnt work however. I have replaced the fuse under the hood for the horn; it didnt help. Is there a fuse I am missing (under the dash for instance?) If there is where is it and what does it look like.
Also, apart from the horn the odomenter dosnt work. Could that be a fuse problem as well.
I knew the car would have problems when I baught it, but it was only $800 - a steal realy. The motor purrs like a kitten. I just want to take care of some of these safty issues, for my piece of mind..any help is greaty welcome.
Thanks,
Rendishions
Feb 25, 2009 at 4:10 AM
TIGER2466
My horn went out and i replaced it and works. My suggestion is get a test light where the fuse is at and make sure there is juice there.
Other then that try another horn fuse, perhaps the one you have in there is the wrong one.
There is only one fuse for the horn if im not misatken which is that block fuse inside the cars main dist center.
Mar 8, 2009 at 12:37 PM
