1993 Saturn SL1 Cooling Fan
135,000 MILES • 4 CYL • FWD • AUTOMATIC
GRAND1963
  • 5 POSTS
My engine cooling fan does not work. What could be the cause of it? Ive replaced all the fuses for it and it still does not work.
May 26, 2010 at 7:15 AM
SATURNTECH9
  • 30,869 POSTS
Does your a/c compressor come on when you turn on your a/c ?If so does your cooling fan come with the a/c?If your a/c doesn't work then look by your underhood fuse box attached to your a/c line there is a high/low switch turn on your a/c then unplug the high low switch there might be a safety tab you may have to remove before you can release the connector .Then get a paper clip jump across the terminals this will force the a/c to come on let me know if the radiator fan comes on with it don't leave it jumped too long.
Jan 2, 2020 at 11:58 AM
