1992 Saturn SL1
BRIANKT123
  • 1992 SATURN SL1
1992 Saturn SL1
Saturn rear suspension parts
Sunday, July 11th, 2010 AT 12:33 PM
SATURNTECH9
  • 30,869 POSTS
What was your question?
Sunday, July 11th, 2010 AT 10:31 PM
BRIANKT123
Saturntech9, I tried to pm you but I haven't posted enough times yet (10). My question was, What is the bar that is visible without having to get under the vehicle in the rear? It is attached to the body near the rear door and then attached behind the rear wheel assembly. There are buschings at both ends that the bolts go through. Is this a torsion bar? Or a rear control arm? Mine snapped. When you hold the tire in your hand you can move it from side to side. I need to get one from the salvage yard & not sure what it's called.
Monday, July 12th, 2010 AT 2:20 AM
