1988 Saturn SL1 car wont turn
1988 SATURN SL1
153,000 MILES • 4 CYL • 2WD • AUTOMATIC
CSCHEURING
my car was in an accident when it was raining, it slid into a guard rail off the freeway. hit on the driver side. when i took the wheel off the control arm was severely bent, so i replaced it. now still on jacks, the steering wheel wont turn. what could the problem be?
Dec 31, 2008 at 12:26 AM
JUSTIN FREED
  • 87 POSTS
Obviously, the control arm was only the MOST visible problem. If you aren't thoroughly familiar with the steering/suspension system, a good reference manual (or online ref) is warranted.
I suggest you take extra special care and examine all parts thoroughly...remove the passenger side tire and compare. If that checks out, suspect the steering gear (if pwr steering - rack).
Dec 31, 2008 at 1:37 PM
