1985 Saturn SL1 Ignition or Alternator?
151,000 MILES • 4 CYL • FWD • MANUAL
FALLONB23
My car ran fine this morning and all day. I went to start the car tonight and it wouldn't turn over. I put the clutch in, turn the key and all I hear is a single click. The heat and stereo are both running though, so I don't think it's the battery. not sure exactly what it is. It was also freezing cold out (-6F). I don't know if this was a factor.
Dec 29, 2009 at 1:37 PM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch,Clutch switch and ignition switch assuming the battery and connections are good.
Dec 29, 2009 at 8:45 PM
