2009 Saturn Sky Instrument panel lights
2009 SATURN SKY
POPJITTERBUG
Electrical problem
2009 Saturn Sky 4 cyl Two Wheel Drive Automatic
With the interior of the car completely black it very hard to see the instrument panel lights (guages) during the day. Is there any way, better than hot wiring) to make the instrument panel lights be on when ever the ignition switch is on without turning the parking or headllights on? I use the auto light mode most of the time. I think my 2009 Saturn Aura works like this. There is no computer menue preference for this that I can find.
Mar 17, 2010 at 1:18 PM
2CARPRO JACK
  • 11,533 POSTS
The entire instrument illumination iny oour Saturn is run by the Body Control Module.I would think that if you wired in anything in the circuit to do what you describe would set a Body Module trouble code.You may be able to find an aftermarket kit for "Automatic Headlight kit" but I cant promise it will work with your vehicle
Mar 19, 2010 at 1:09 AM
