2007 Saturn Sky Leaking / Venting rearend
40,000 MILES • 4 CYL • 2WD • AUTOMATIC
TRIKE4PLAY
This is an ongoing problem and the dealership just puts on a longer vent hose and new vent cap . I feel this is just masking a problem.
The vent tube has just been replaced for the third time and it was leaking when we got home after the 50 mile drive from the dealership. GM / Saturn TSB#07-04-20-001A is what they are quoting????
What is this a problem and how can it be fixed?
Jan 10, 2010 at 9:49 AM
DOCFIXIT
  • 18,828 POSTS
TSB is correct longer vent hose and metal vent cap. Suggest you contact GM see owners manual for contact and schedule a meet with area service rep. This will document problem so when you run out of warrenty and they find a fix you will be covered.
Hope this helps
Thanks for donate
Jan 12, 2010 at 12:45 AM
