1998 Saturn Sky Engine stalling
150,000 MILES • 4 CYL • FWD • AUTOMATIC
HORSESHOE777
My 1998 Saturn SL1 engine stalls intermittently after it reaches operating temperature. It will not start back up until I wait 5 or 10 minutes. It doesn't happen all the time, but seems to be happening more often of late. Any suggestioins?
Oct 1, 2009 at 3:03 PM
SATURNTECH9
  • 30,868 POSTS
sounds like its probably the engine crank sensor usually doesnt set a code for that the only way to diagnose it with out a code is wait till it happens and wont start and have a scan tool handy that will read engine data and watch the rpms on the scan tool while u crank the engine when its not starting if it reads 0 rpm while cranking bad crank sensor.unless u want to just take a chance and change it thats the most likely cause i have seen alot of them do that very same thing very random dieing hard to diagnose unless it just fails good luck let me know how it goes.
louie
Oct 2, 2009 at 11:26 AM
