2002 Saturn Sedan Vehicle shakes or sluggish when accelerat
2002 SATURN SEDAN
MIKEJANNELL
Drive Train Axles Bearings problem
2002 Saturn Sedan 4 cyl Front Wheel Drive Manual
When I take my foot off the gas or when I accelerate my car seems to be sluggish. It is almost as if something is dragging or slowing the car down. After I accelerate and pick up speed it stops and runs fine. I was told maybe it is due to low transmission fluid but it's a manual transmission and I don't think fluid is the problem.
Mar 3, 2010 at 7:29 AM
LEGITIMATE007
  • 5,121 POSTS
take a look at the spark plugs and wires, take each wire and easily bend it to and fro up and down each wire, if you run into a hard spot and it feels like it crumbled inside when you gently bend it , then that is your problem also make sure they arent melted against the block and arcing,(shooting a spark between the wire and the block)
Mar 3, 2010 at 8:00 AM
