2002 Saturn Sedan clutch
2002 SATURN SEDAN
MR.E
2002 Saturn Sedan
dpress the clutcj and the engine does not crank,battery is charged.pin on clutch going into cable fell out,put bsck in but still no crank with clutch pushed down
May 21, 2010 at 10:41 PM
Inspect and test the clutch switch
May 22, 2010 at 5:05 AM
MR.E
correction 2000 saturn . i usd a jumper wire on switch wire that had power to it, still does not turn over.. i tested the connection to the switch which had power so i used a jumper wire still the motor does not turn over,i am guessing a ground wire on starter or starter is bad. i really wanna thank you for your help
May 25, 2010 at 11:25 PM
