2000 Saturn Sedan OIL COOLER REPLACED
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
RANDY MAYEUX
i JUST REPLACED THE OIL COOLER IN MY 2000 SATURN LS2 BECAUSE IT WAS LEAKING OIL INTO MY COOLANT. MY QUESTION IS HOW DO I FLUSH OUT THE OIL SATURATED COOLANT OUT OF THE COOLING SYSYTEM
May 9, 2009 at 2:48 AM
MIKE H R
  • 3,094 POSTS
you should be ok just changing the coolant fluid. but if you want everything out then you will have to flush the system. As long as there is not a major amount in the coolant you should get away with just changing the coolant
May 9, 2009 at 5:28 AM
