1999 Saturn Sedan won't start
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
CARDELLOKURT
Daughter needs help in Boston......need advice for trustworthy mechanic in Longwood ave area to assist her.
Oct 18, 2009 at 8:04 AM
  • 75,988 POSTS
Might want to do below to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 18, 2009 at 8:37 AM
