1998 Saturn Sedan RADIATOR
1998 SATURN SEDAN
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRUMP0428
I NEED TO DRAIN RADIATOR. WHERE IS THE DRAIN PLUG LOCATED?
Dec 7, 2009 at 12:43 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
its in two places one on the radiator on the bottom passenger side.and theres a block drain if u follow the lower radiator hose to the engine thats where the thermostate housing is on the underside u will see a 10mm bolt u take it out and the rest of the coolant u didnt get out with the radiator drain comes out dont loose the washer for the bolt thats the seal for it its reusable let me know how it goes.
louie
Dec 7, 2009 at 4:46 PM
