1998 Saturn Sedan "Service Engine Soon"
1998 SATURN SEDAN
145,000 MILES • 4 CYL • 4WD • MANUAL
MITCH8013
1998 Saturn P0109 = Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent. why is this an intermitant problem. These are the hardest to rind, However the "OBD2" foung this code. Will a used junk=yard "Map=Sensor" be sufficiant enough? I know that, because I had to replace one back in 1992 on my Chey Z-24, which is no longer in production. Cost? = $385.00 for a NEW replacement! I am disable on SSDI, I can't afford alot. I bought the car used just 16 days ago. I also had a very rough idle since day one. After "
OBD@ teast I had two codes:
1) PO302 - CYLINDER 2 MISFIRE (I replaced all of the plugs with "Bosh". Rough idle is gone.
Please Advise as to what I should do and the cost to fix this problem.
Thank you,
distrought,
M. Foote
Sep 9, 2009 at 5:54 PM
  • 31,937 POSTS
HI there,
Thank you for the donation,
I would try the 2nd hand map sensor, also check the vacuum hose and make sure that the harness plug is a snug & tight fit, also look at the pins and inspect for any loose or corroded pins in the plug.
mark (mhpautos)
Sep 9, 2009 at 9:28 PM
