2002 Saturn SC2 cooling fan
149,762 MILES • 4 CYL • FWD • AUTOMATIC
TPARDINAS
my sc2 over heats unless the ac is on. the cooling fan will only come on with the ac on. i replaces the coolant temp sensor below the water neck and still doesnt work. what else can i do?
May 13, 2010 at 3:30 PM
SATURNTECH9
  • 30,869 POSTS
[quote:03d170b4f3="TPardinas"]Engine Cooling problem
2002 Saturn SC2 4 cyl Front Wheel Drive Automatic 149762 miles
my sc2 over heats unless the ac is on. the cooling fan will only come on with the ac on. i replaces the coolant temp sensor below the water neck and still doesnt work. what else can i do?[/quote:03d170b4f3]
when u replace the coolant temp sensor did u inspect the connector for corrosion if it's corroded it will have to be replaced that could give the PCM the incorrect temp.also how do u know it's over heating does it boil over and out of the coolant bottle cap?what does the temp gauge read when it's over heating?
May 14, 2010 at 4:13 AM
