2001 Saturn SC2 Serpentine belt replacement
2001 SATURN SC2
CHRISD74
Engine Mechanical problem
2001 Saturn SC2 4 cyl Front Wheel Drive Automatic
Hi, I have to replace the serpentine belt due to cracks and wear and have heard that it is a nightmare to change because of the limited space. Do you know of any tricks to make this job easier and quicker?
Thanks in advance,
Chris
Oct 25, 2010 at 10:22 AM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
You can change it without removing the upper motor mount but it is a lot more challenging i support the engine with a floor jack remove the upper mount and jack the engine up and that will give you plenty of room to change it.Make sure you use a piece of wood between the jack and mount.
Oct 25, 2010 at 10:27 AM
