1999 Saturn SC2 Won't turn over
120,000 MILES • 4 CYL • FWD • AUTOMATIC
BUDMAN2909
My car stopped working a week ago today so September 19, 2009. It has full power in the car except the radio wont turn on. The battery and fuses are all good. I replaced the starter and solenoid, and i also replaced the ignition switch. It still won't turn over and it doesn't even try to turn over.
Sep 27, 2009 at 1:55 PM
  • 75,988 POSTS
Are you saying its cranking over and refuses to start or just won't crank at all/nothing?
Sep 27, 2009 at 9:47 PM
BUDMAN2909
Ya it's not cranking over at all. When it first happened you couldn't hear anything but the fuel pump. After i replaced the starter/solenoid the only thing you still could hear was the fuel pump. Then i changed the ignition switch it would make just a click sound just one. But it's still not coming close to turning over.
Sep 28, 2009 at 1:39 AM
  • 75,988 POSTS
Okay since you've changed the ignition switch that takes it out of the pic. Get a heloer to hold key at crank position and check for power at the small terminal that has the purple wire-if you have check the battery terminal connection on it-if okay -retest the starter If not do below Make sure the battery has atleast 12.4 voltage or better Check and test the ign 3 fuse 30amp, starter relay, and park/neutral switch-Let me know
https://images.2carpros.com/forum/automotive_pictures/12900_starter1_22.jpg
Sep 28, 2009 at 5:45 AM
