I am just trying to get the correct procedure for removing the shift cables from the transmission housing. Thanks
Aug 26, 2010 at 8:31 AM
SATURNTECH9
✓Experienced Mechanic
What is wrong with your cable's?You might be able to fix them they sell repair kit's a lot cheaper and easier then replacing the cable's.Did the outer cable end come off the inside shifter?
