1999 Saturn SC2 raditor gauge will not register correctly
264,000 MILES • 4 CYL • 2WD • MANUAL
DONAHUEC
  • 5 POSTS
After my car has been running for a while the raditor gauge will not register correctly and I have had the reservor change and the cap and still the gauge does not read correctly. What could be the problem
Jan 21, 2010 at 6:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if coolant temperature gauge is reading incorrectly then you need to check the engine coolant temperature (ECT) sensor.
Jan 21, 2010 at 6:45 PM
DONAHUEC
  • 5 POSTS
Thank you I had the ECT sensor change and that fixed the problem.
Jan 24, 2010 at 12:49 PM
