1999 Saturn SC2 oil saturated spark plugs
144,000 MILES • 4 CYL • 2WD • MANUAL
DOWLING10
I recently went on a long trip on the way back my engine had a severe loss of power when taking off and accelerated when i got home went to change the plugs and wires when i took the plugs out they were covered in oil, obviously oil is leaking internally could you tell what would cause the oil to leak into the sparkplugs
Sep 10, 2010 at 8:20 AM
  • 75,988 POSTS
Do an engine compression check, possibilities could be valves, rings, seals and cylinder wear
Sep 10, 2010 at 9:01 AM
