1999 Saturn SC2 leaks in car when rains
1999 SATURN SC2
264,000 MILES • 4 CYL • 2WD • MANUAL
DONAHUEC
  • 5 POSTS
On my driver and passanger side door when it rains it leaks into the car could this be the door moulding that need to be changed due to wear. If so how do I make the change. Also the rear window defogger light will not work is this a fuse or need to change the back defogger in the window
Jan 22, 2010 at 8:07 PM
LEGITIMATE007
  • 5,121 POSTS
the defogger is a fuse problem however it could be disconnected at the window, or one of the lines has been scratched causing a break in the flow of voltage. as far as the leak, these things are hard to find, I would first check in the door jamb, check for clogged leaves and debris and clear it out, also the cowel you will have to look inside to see if leaves have cause a blockage of the drain.
Mar 19, 2010 at 2:38 AM
