1998 Saturn SC2 TRANSMISSION FLUID SENSOR
1998 SATURN SC2
94,000 MILES • 6 CYL • FWD • AUTOMATIC
DEE MATT
ENGINE LIGHT ON PEP BOYS SAYS TRANSMISSION FLUID TEMP IS HIGH BUT IT COMES ON IMMEDIATELY WHEN STARTED. CAN THIS BE CHANGED EASILY AND WHERE IS IT ON 1998 MODEL??
Jan 19, 2009 at 12:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your tranny fluid temperature sensor is located in the front left of the engine compartment. It will have a two pronged plug on the back of it. The plug simply snaps in. Gently unplug it, then unscrew it from the engine.
Thanks for using 2CarPros.com!
Jan 19, 2009 at 12:29 PM
DEE MATT
It is not visible on top is it underneath car?? Thank you you guys are awesome!!
Jan 21, 2009 at 1:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, sorry. You will have to go underneath vehicle to reach it.
Jan 21, 2009 at 3:12 AM
