Drive Train Axles Bearings problem
1998 Saturn SC2 4 cyl Front Wheel Drive Automatic
My sons 98 Saturn SC2 has some steering wheel shimmy at highway speeds. Put the car up on stands, visually checked suspension, steering linkage, etc. and all seems to be solid. I did however find excessive play in the coupled section (not cv area) of the passenger side half shaft and thinking this may be causing the problem. I dont think the alignment is off as the car will track fine. Could the half shaft be the problem?
Apr 9, 2010 at 10:31 AM
