1998 Saturn SC2 crank position sensor
200,000 MILES • 4 CYL • FWD • AUTOMATIC
ANITACHARLIE
My car started fine today and turned her off and went into a store, when I came out she would not start till after 3 + tries could the crank position sensor be the problem. This has happened twice before. Please help. anitacharlie
Feb 3, 2009 at 8:29 AM
  • 75,988 POSTS
To catch this problem do below immediately then tell me what's missing
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 3, 2009 at 9:49 AM
