1998 Saturn SC2
PASCAFF
1998 Saturn SC2
How do you gain access to the electronic window switches in the console.
May 10, 2009 at 8:15 AM
2CARPRO JACK
  • 11,533 POSTS
My software doesnt give that info, but they usually just pop into the console or a plate that both switch's mount to.Most cars now use retainers that pop in to hold almost all of the interior together.Try using a wide blade to get under the front or rear of the switch and gently pry up, if it doent give a little then you may have to remove the console
May 11, 2009 at 1:03 AM
