where is the drain that needs to be cleaned so I don't get water in the floor boards when it rains.
Jul 3, 2010 at 8:22 AM
SATURNTECH9
✓Experienced Mechanic
Do you have a sunroof?Is the water coming from the headliner?
Jul 3, 2010 at 9:09 AM
HANKTHECRANK
MEMBER
The water is entering through the fresh air vents below the front windshield and filling up the airconditioning ducts. The drain for the ducts under the dash is clogged. I was hoping to find out where this drain is so I can unclog it. Thanks.
Jul 3, 2010 at 11:57 AM
SATURNTECH9
Oh the a/c drain it's on the firewall engine compartment toward's the middle about half way down.Use a metal coat hanger and watch out because there is going to be alot of water comming out.
Jul 3, 2010 at 12:34 PM
HANKTHECRANK
MEMBER
Great answer. Thanks a lot. Went right to the drain from underneath car and reamed it out with coat hanger. Now let's see what happens when it rains.
