1997 Saturn SC2 car speedometer
95,688 MILES • 4 CYL • FWD • MANUAL
LAXKINGOF2007
when i start the car the speedo needle reads below zero. when i drive approx. 10 mph the speedo reads 0 mph. what is/are the best ways to fix this problem?
Jan 20, 2010 at 10:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you having any issues with transmission shifting? is the odometer still reading and working properly?
Jan 20, 2010 at 11:02 AM
THEJAKE77
  • 8 POSTS
I have the same problem you have. The speedometer and odometer do not work at all and I'm also having issues with the transmission shifting wildly or sometimes sticking in one gear at high RPMs. Any ideas? Could all of these problems be related?
Thanks in advance!
Oct 29, 2012 at 5:22 AM
SATURNTECH9
  • 30,869 POSTS
Do you have the same year and model?Any codes in the computer?
Oct 29, 2012 at 8:19 PM
THEJAKE77
  • 8 POSTS
Yes, my car is also a '97 SC2. And according to the guys at my local Tuffy Muffler, there were no codes on their diagnostic. Although that didn't stop them from charging me $39.99 for it anyway...
They just repaired the flex pipe on my exhaust and gave it an oil change and sent me on my way. Needless to say, there are definitely more things wrong with it than that! My 'SERVICE ENGINE SOON' light has been on since I bought the car.
Oct 29, 2012 at 11:53 PM
SATURNTECH9
  • 30,869 POSTS
If the check engine light is on you should have codes if you dont live in California you should be able to go to a auto parts store and have them check for codes?
Oct 30, 2012 at 8:46 AM
THEJAKE77
  • 8 POSTS
I live in Michigan, so I will get on top of that ASAP and get back to you! Thanks for your time! I greatly appreciate it!
Oct 30, 2012 at 11:30 AM
THEJAKE77
  • 8 POSTS
I live in Michigan, so I'll get on top of that ASAP and get back to you soon. Thanks for your time! I greatly appreciate it!
Oct 30, 2012 at 11:33 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome keep me posted with exact code numbers not code descriptions.
Oct 30, 2012 at 12:48 PM
THEJAKE77
  • 8 POSTS
Will do!
Oct 30, 2012 at 12:50 PM
THEJAKE77
  • 8 POSTS
The codes I got were P0500 and P0722. I'd greatly appreciate any advice you could give me to repair these problems myself. Thanks!!
Nov 2, 2012 at 7:46 AM
SATURNTECH9
  • 30,869 POSTS
Those are both for the output speed sensor which is right by where your right side axle comes out.Inspect the wiring to it those sensors rarely fail.Also do you have a multi meter to do some testing?
Nov 2, 2012 at 6:01 PM
THEJAKE77
  • 8 POSTS
I do indeed have a multi meter. It doesn't surprise me to hear that is most likely an electrical problem. The car sat parked out in the elements for over 2 years before I bought it. But I'm hoping with some minor repairs and a little TLC, I can get it to run properly for a few more years. It only has approximately 76k miles, which is the last reading on the odometer before it stopped working.
Nov 4, 2012 at 6:49 AM
SATURNTECH9
  • 30,869 POSTS
So how was the wiring to the sensor?
Nov 4, 2012 at 6:30 PM
THEJAKE77
  • 8 POSTS
Sorry it took me so long to respond - you were right, the speed sensor itself was fine, it was simply a frayed wire. A little splicing and some electrical tape solved the problem! Thanks for your help!
Nov 26, 2012 at 8:55 AM
SATURNTECH9
  • 30,869 POSTS
Figured thats what it was glad to hear you have it fixed now.Your very welcome that's what were here for.
Nov 26, 2012 at 9:54 AM
