1997 Saturn SC2
JOSHUAT_14
  • 1997 SATURN SC2
Electrical problem
1997 Saturn SC2 4 cyl Two Wheel Drive Automatic
Replaced driver door and car won't crank.
Sunday, January 17th, 2010 AT 9:12 PM
SATURNTECH9
  • 30,869 POSTS
Thats really strange so does the car crank and not start?Or does the engine just not crank over at all?Can u hear the starter click?
Monday, January 18th, 2010 AT 12:18 PM
JOSHUAT_14
When I turn the key the dash lights come on and there is a click but the engint doesn't even try to turn over.
Monday, January 18th, 2010 AT 8:46 PM
SATURNTECH9
  • 30,869 POSTS
So the clicking u hear is that comming from ur starter?Have u tested ur battery with a volt meter when u turn ur key to see what voltage it reads? Have u checked to make sure ur battery cables are clean and tight?Let me know what u find.
Tuesday, January 19th, 2010 AT 3:29 PM
JOSHUAT_14
The clicking is coming from the fuse panel in the passenger floorboard. I tried taking the terminals off and cleaned them and I got a good connection to the battery. I've switched the circuit breakers and checked all fuses. Any other suggestions I might've missed?
Thursday, January 21st, 2010 AT 6:54 AM
SATURNTECH9
  • 30,869 POSTS
That clicking ur hearing is ur fuel pump relay. We need to find out where ur power to ur starter is and isnt when u turn ur key. Look in ur underhood fuse box see if ur ign3 fuse has power and is good. Also does ur dash lights all come on when u turn the key on?Do u have a volt ohm meter or test light?Let me know.
Thursday, January 21st, 2010 AT 1:44 PM
