Engiine will occasionally stall at idle or emmediately when gas pedal is depressed, or will hesitate. I have checked plug gaps, verified fuel pressure, and injector operation. Removed and cleaned iac valve, and this greatly improved problem. Still has slight hesitation on take off. Should I chang iac valve?
Oct 8, 2009 at 2:50 PM
