1997 Saturn SC2
JOSHUAT_14
Electrical problem
1997 Saturn SC2 4 cyl Two Wheel Drive Automatic
Replaced driver door and car won't crank.
Jan 17, 2010 at 1:12 PM
SATURNTECH9
  • 30,868 POSTS
thats really strange so does the car crank and not start?or does the engine just not crank over at all?can u hear the starter click?
Jan 18, 2010 at 4:18 AM
JOSHUAT_14
When i turn the key the dash lights come on and there is a click but the engint doesn't even try to turn over.
Jan 18, 2010 at 12:46 PM
SATURNTECH9
  • 30,868 POSTS
So the clicking u hear is that comming from ur starter?have u tested ur battery with a volt meter when u turn ur key to see what voltage it reads? have u checked to make sure ur battery cables are clean and tight?let me know what u find.
Jan 19, 2010 at 7:29 AM
JOSHUAT_14
The clicking is coming from the fuse panel in the passenger floorboard. I tried taking the terminals off and cleaned them and I got a good connection to the battery. I've switched the circuit breakers and checked all fuses. Any other suggestions I might've missed?
Jan 20, 2010 at 10:54 PM
SATURNTECH9
  • 30,868 POSTS
that clicking ur hearing is ur fuel pump relay.we need to find out where ur power to ur starter is and isnt when u turn ur key.look in ur underhood fuse box see if ur ign3 fuse has power and is good.also does ur dash lights all come on when u turn the key on?do u have a volt ohm meter or test light?let me know.
Jan 21, 2010 at 5:44 AM
