1996 Saturn SC2 transmission no longer shifts once at runni
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEINECKER31
  • 5 POSTS
once my 96 saturn sc2 gets to running temperature it will not shift out of the lower gears, i believe it has something to do with the temperature because it will run much longer in the winter than in the summer before the problem arises. any ideas?
Jul 14, 2010 at 8:16 PM
SATURNTECH9
  • 30,869 POSTS
Let's start with you going to a auto part's store like auto zone and getting me the code number's it has.Does your transmission shift hard?Do you have a delay in reverse?
Jul 15, 2010 at 4:56 AM
STEINECKER31
  • 5 POSTS
yes i do have the reverse slam that everyone talks about, i was also wondering if replacing the valve body could be a solution for the shifting problems i"m having?
Jul 16, 2010 at 7:04 AM
SATURNTECH9
  • 30,869 POSTS
If you could check those code's for me that would help me make a decision on which way i would go on the repair's for your car.Also check your fluid level when the car is warmed up on flat level ground.Also check what color it is milky,black,sliver or red?
Jul 16, 2010 at 8:09 AM
STEINECKER31
  • 5 POSTS
ok i will check the codes as soon as i can get out of the house, the transmission fluid is black, and at the correct level, im pretty sure it is the valve body based on what ive read on other sites, how do i know if i have a mp7 or a TAAT unit though? its a 96 sc2
Jul 16, 2010 at 9:14 AM
SATURNTECH9
  • 30,869 POSTS
If the fluid is black you haven't changed it in a long time your suppose to change it every 30,000 miles at that mileage it's still redish.That year and model came with both the mp6 and mp7 transmission's.To see which one you have go in the trunk on the drivers side under the carpet on the spare tire cover there will be a sticker with a bunch of code's on it you will see a mp6 or mp7 on that sticker.Let's get those code's though and go from there.
Jul 16, 2010 at 10:47 AM
STEINECKER31
  • 5 POSTS
ok it said mp7 on there. i will change the transmission fluid and filter tommorrow, but do you know if they sell remanufactured valve body for that model of transmission?
Jul 16, 2010 at 11:17 AM
SATURNTECH9
  • 30,869 POSTS
For the fluid i would use the castrol high mileage transmission fluid in the green bottle's.That's what i have been using in all my saturns and family's saturns.They sell it at some of the walmarts.On the filter i would try to get a fram one that's who make's the factory one's.They do have factory recondition valve body even saturn one's.There is a lot of rebuilt one's out there.I have only used the saturn rebuilt one's so i don't know of a good place to get one but they are reasonable.Your looking for the one's for the taat transmission.If you look online you will probably get the best price.
Jul 16, 2010 at 12:39 PM
STEINECKER31
  • 5 POSTS
so i can buy a remanufactured body valve for the taat transmission and it will still work fine in my mp7?
Jul 17, 2010 at 8:26 PM
SATURNTECH9
  • 30,869 POSTS
Yes even Saturn has them I belive you can only get a remanufactored ones from Saturn.They will work fine.
Jul 18, 2010 at 8:47 AM
