1996 Saturn SC2 reverse function
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
JWILIAMS
Is the trans. on a 1992 sc the same as the sc2,where as there is a nut that backs off reducing hydro presure.Have 1996 sc2 that has lost rev.the 1992 has a panel you can open on drivers side and ajust. one time only deal
Mar 20, 2010 at 4:36 AM
SATURNTECH9
  • 30,869 POSTS
[quote:af9ccae936="jwiliams"]Transmission problem
1996 Saturn SC2 4 cyl Two Wheel Drive Automatic 100000 miles
Is the trans. on a 1992 sc the same as the sc2,where as there is a nut that backs off reducing hydro presure.Have 1996 sc2 that has lost rev.the 1992 has a panel you can open on drivers side and ajust. one time only deal[/quote:af9ccae936]
I haven't seen many early saturns like the 92 input shaft nut loosen up it's usually 98 an up.u can try it for ur 96 u will have to get a new input shaft nut an replace it along with a side cover gasket and some anerobic sealer.it's most likey a bad valve body.do u have any codes?let me know.
Mar 20, 2010 at 7:33 AM
