1996 Saturn SC2 oxygen sensors
145,000 MILES • 4 CYL • FWD • AUTOMATIC
KANCAR
My engine service light is on all the time . had codes read. was told that both oxygen sensors need to be replaced. can i use universal sensors for both. was also told car would drive fine just as it is by some people. how important is it that i change the sensors. what are the short and long term consequences of not changing it.
Apr 13, 2010 at 12:10 PM
SATURNTECH9
  • 30,869 POSTS
Driving with bad o2 sensors will damage ur cat build up excessive carbon in ur engine.could cause ur car to run lean also.u can use universal o2 sensors u just have to wire them up.what codes did u have what numbers are they u usually don't get two bad sensors at the same time.let me know.
Apr 13, 2010 at 2:19 PM
