1996 Saturn SC2 altnator
110,000 MILES • 4 CYL • 2WD • MANUAL
CHRIZZZZ1
i have replaced the altnator twice and still wont charge the battery took the altenator to auto zone and tested good but in the car tests bad regulator i have tested the wires and the altenator is putting out the right voltage and all the wire are in good contiton and none of the fuses are blown and now i dont know were else to look
Oct 29, 2010 at 5:28 AM
SATURNTECH9
  • 30,868 POSTS
First of all thank you so much for your donation.There is a fuse able link that run's from the starter to the back of the alternator remove it take a ohm's meter on low scale setting and check it from end to end you should have 2 ohm's or less reading.Let me know what you find and we will go from there.
Oct 29, 2010 at 5:44 AM
