1996 Saturn SC2
BUDROW
1996 Saturn SC2
i need to know how to replace the fuel filter on a 1996 saturn sc2 thanks for the help
Jan 8, 2010 at 3:16 AM
SATURNTECH9
  • 30,869 POSTS
That's an easy replace when the cars cold hooked to ur fuel injector rail is the fuel filter follow the line down to ur fuel filter mounted to the body rail keep going down the filter till u come to where the fuel line hooks to the bottom.squeese the two tabs in pull the line off.now go back two u the intake remove the 10mm bolt holding the line in place then squeese the two tabs holding the line to injector rail remove line.now go back down to the fuel filter holder u can bend back the plastic tabs far enough so u can slide the filter.reverse to put the new one in.let me know how it goes.
Jan 8, 2010 at 8:39 AM
